profile.country.SE.title
MickeJGS
Pixelation issue
What does SONY means with especially if you use a CI+ module smartcard
Or does SONY mean you can get pixelation issue on screen not using a CI+ module smartcard watching TV?
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/xr-50x90j/article...
[quote]The pixelation issue might occur on the following TV models, especially if you use a CI+ module smartcard to watch TV. Make sure your TV series is included in the list below:[/quote]
9 REPLIES 9
IamNic
Hello @MickeJGS,
there was an issue with certain CAM/CI modules which caused macro blocking.
There has been an update today for many TVs, which has resolved this issue.
Which TV do you use?
- Nic
MickeJGS
I have the XH90/X900H and i have some problems with pixelized screen for a few second, but watching through apple tv
How sony is describing the issue is what it looks on my screen... but i guess same issue can't be happening from other sources?
IamNic
Hello @MickeJGS,
the pixelation you see is from your Apple TV playing a low resolution stream before the high quality version is buffered - completly other topic.
- Nic
MickeJGS
How do you know it's low resolution from my Apple TV?
HannahEd01
Hey MickeJGS, I just replied to your other thread, let's keep it in one place please.
MickeJGS
pixels and green bars are 2 totally different issues with this tv
MickeJGS
How sony is describing the pixelation issue , when i, at sometimes see individual square pixels on my TV screen for a couple of seconds or longer
Apparently you only can get the pixelation issue through a a CI+ module. If you get same pixelation issue on your TV screen watching from APPLE TV, then it's wrong with your APPLE TV nothing wrong with your TV!
In February 2022, Sony has begun rolling out a new software update that solves occasional pixelation or blurring (also known as macro-blocking) when watching TV with a CI+ module. If you can sometimes see individual square pixels on your TV screen, please follow the steps in this article to get the new software update.
Note: The software update is rolled out gradually and its exact timing can differ depending on the TV model.
Step 1: Check the applicable TV models
  • 2021 Sony Android TVs: X80J, X81J, X82J, X85J, X89J, X90J, X92J, X93J, X94J, X95J, A80J, A83J, A84J, A90J and Z9J Series
  • 2020 Sony Android TVs: XH90 and XH92 Series
IamNic
Hello @MickeJGS,
because every streaming service shows this phenomenon. If a stream is not pre-buffered you might experience low resolution/pixelation/blocking for a few seconds until the high res or 4K stream kicks in.
I had this happen on Netflix and Amazon prime video, no matter if it was the app installed on the TV or via a FireTV stick or my Blu-Ray player connected via HDMI.
So from your description I am sure it is your Apple TV showing the low quality stream for a few seconds.
- Nic
MickeJGS
I see not this kind of pixels with NETFLIX, PRIME, HBO or DISNEY
But all apps i see "live channels"
I have about 5 of those apps, pixels issue on all 5, so i don't think it's a APPLE TV issue but a SONY issue, but SONY wount admit this as their issue, they can always blame on 3rd part how you connect something to the TV
