Plz explain the real specs of this tv(sony kd x80e) given below....at first portion it says that it has native Refreshing rate of 50 hz but in second portion it says that it can support 4k video signal at 60 hz..
so is it 50 hz or 60 hz tv?
Motion enhancer (Native Hz) Motionflow™ XR 200 (Native 50Hz)
Video signal support 1080p (50, 60 Hz), 1080i (50, 60 Hz), 720p (50, 60 Hz), 576p, 576i, 480p, 480i 4096x2160p(24, 50, 60Hz), 3840x2160p(24, 25, 30, 50, 60Hz),1080p(30, 50, 60Hz), 1080/24p, 1080i(50, 60Hz), 720p(30, 50, 60Hz), 720/24p, 576p, 576i, 480p, 480i
Hi sky121,
Welcome to the Sony Community.
Can you let me know your exact TV model?
Cheers,
Sean Mc
KD-55X8000E
This is an asian model while non asian model is XBR x800e which is 60hz(240 motion flow).....after checking the specs of XBR model of x80e i bought this led for gaming at 60 fps on 4k.......but unfortunatily i bought KD model dunt knowing that this is downgraded x80e 50hz (200motion flow) asian model similar to x70e....
now the dealer at sony franchise wont return it or change it with different model as it does not come under warranty return policy..
helo thnx for ur reply...
here under its specs it says that it has native 50 hz
Motion enhancer (Native Hz) | Motionflow™ XR 200 (Native 50Hz) |
Hi @sky121,
I am not certain, yet I think this does refer to the European PAL standard and the integrated tuner.
It means, that the TV does interpolate 50Hz TV signals to 200Hz, yet it has nothing to do with external signals like your 60fps PS4.
- Nic
