- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
							PROBLEM WITH TURNING UP AND DOWN THE VOLUME
Hello.
I have a KD-55XG8596 tv but I've benn experiencing a problem with turning up and down the volume. When I press the buttom continiously it just doesn't work and to change the volume I need to press the -/+ once, release it and then do it again.
I will appreciate if someone can help.
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try just a reboot of Android TV, keep pressed Power/OFF on remote...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's a nuisance but at this point you can think of a factory reset, after it must work...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You are assuming this must be a TV problem, but it could be a problem with the remote.
I would check the batteries, maybe try fresh ones, anyway leaving them out for at least one minute, and see if this helps.
If not, here is Sony’s comprehensive troubleshooting guide for remote issues:-
https://www.sony.co.uk/electronics/support/articles/00030297
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I hope the troubleshooting on remote can help... 🤗
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've also had volume issues with my KD-43XF8505 too, but a slightly different problem.
Randomly, when turning volume up or down, I would make one volume button press, but the tv would continue to raise or lower volume to its maximum or minimum volume?!
Anyone else had this issue?
