"not connected to wifi" pop-up on top right of screen
davidm50
Annoying grey pop up appears on the top right hand of the screen telling me the tv is not connected to the internet, although the tv seems to be functioning OK. How do I stop this??
1 REPLY 1
ancaise
if your not using the internet for anything like netflicks etc then just go into settings -> network and turn off the wifi and unplug any LAN cable if you have one connected.
