Are you recording anything using the Rec Timer? I think mine does that...it's something like that!! Maybe look through the user manual, it should mention it somewhere!
If you mentioned the model number of this TV, i might be able to assist you in turning off this light.
If it’s an A84J then the orange light on the bottom bezel is a mic on indicator.
Hey yeah, that sounds right..mic light
Hi
It’s a XR-50X94J.
Problem solved and not come back. Thanks for the advice.
Regards
J
Can you mark the post that was the solution for other members of the Community. We believe it was from the Google Assistant and indicated that the TV was "listening" with the Mic on for "OK Google" was this correct? Did you switch off the feature in settings?
**EDIT**
It shows when programs are due to be recorded using the Rec Timer
