D-Law81
Sony 43xg8396 (eARC)
Hi is sony going to do a update to the 43xg8396 to allow EARC for HDMI 2.1 as I have the xf9000 sound bar.
D-Law81
OK i love the TV and Sound bar i have also ordered a HDMI 2.1 CABLE to link TV and Sound bar together. May do nothing but think i should. Will see what PS5 comes with.Thanks.
10 REPLIES 10
The HDMI 2.1 in the TV would be an "hardware update", so... No update.
D-Law81
OK but the TV says it can run atmos.? Thank for your answer.
Atmos? No...:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-43xg8396/speci...
Sound (Processing)
    • SOUND MODES
      Standard,Dialog,Cinema,Music,Sports
    • DOLBY AUDIO FORMAT SUPPORT
      Dolby™ Digital, Dolby™ Digital Plus, Dolby™ Pulse
    • DTS AUDIO FORMAT SUPPORT
      DTS Digital Surround
    • SIMULATED SURROUND SOUND
      S-Force Front Surround
    • FM RADIO
      No
    • SOUND PROCESSING
      ClearAudio+
D-Law81
This shows atmos on my TV.
D-Law81
LightFoot
Specialist
Hi @D-Law81   You don't need eARC for Dolby Atmos (DD+). It runs fine over ARC and HDMI 2.0.
D-Law81
LightFoot
Specialist
Hi @D-Law81   HDMI 2.1 is for 8K !
D-Law81
Its also for true HD, ATMOS and DTS X. and yes it looks like i cant run this but won't do any harm. 😉😋👍🇬🇧 Thank you for the answers.
