SONY BRAVIA ANDROID TV STUCK AT BOOT LOOP
Gokul20
I tried the following steps
1) plugout
2) hold power and volume down buttons on the tv
3) plugin
4) hold it until the light bar goes green
5) release the buttons
and it turned green even if i let go or not it crashes and reboots again i have tried that for over 40 times already but i see no change. So i need help to fix this issue as soon as possible. Thank you very much.
2 REPLIES 2
hej fik du løst problemet jeg har samme fejl
Jiw237
I had this issue last year, the motherboard had failed, it had to go away to be repaired unfortunately
