Sony Kdl W755 software an fw crash, error 2123
tmarko
Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
225 REPLIES 225
loquini
Hi Quinnicus
Same problem here, please help,,maybe your solution can be applied to my TV: XBR65X850C
Thanks
Hi
I am having the same problem on a 50W755C. Could you share the details?
Many thanks.
Anonymous
Not applicable
Hi @loquini and @gileshoughton
I have sent you both a PM with some instructions.  Let me know how you get on.
gdzl44
Hi! Could you please send me these instructions - I'm experiencing the same problem with my KD-55X8507C. Thank you!
Anonymous
Not applicable
Hi @gdzl44
Ive sent you a PM with some instructions.  Please let me know how you get on.
Fantastic - thank you!
didievilempire
Hello !!
 Please.
My english is bad. 😃
I have the same problem with a XBR-55X855C (Android) the upgrade goes to 85%.
Thank you.
Edgar.
adyjay33
Take it back and say the firmware supplied by Sony killed it....
KD-55X8509C LATEST FIRMWARE
NOT A HAPPY CUSTOMER!
Anonymous
Not applicable
Hi @didievilempire
Can you confirm which country you are located it, as the model of your tv, XBR indicates you are not in the UK or Europe?
michalsima_90
Hi @Anonymous, I have the same problem. Can you please tell me what to do?
Thank you very much !
