Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
it working !!!!
Dear Quinnicus,
I have a kdl-50W756C same issue (2123) while updating software.(wired / wireless).
Could you please help me.
Thanks
Hi @MaartenTi
Ive sent you a private message with some instructions. Let me know how you get on.
Hi, I have KDL55W805C and the same problem.
Can you please help me?
Thanks,
Hi @dejvid
Thanks. It works
I am having the same issue
i have a Sony android KD x8500 c
till now I am not able to update with same error 2123
Hi @shinas
could you help me aswell?
I have a sony KDL-50w755c TV. It wont update always crashes doing download because of "network problems" (cant remember error number).
I tried both WiFi and cabel connection and factory reset doenst work either.
Hi @bilze23
