Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi There,
I have sony KD-65x9000c and have the same issue during the update.
Could anyone please me the instruction on fixing the issue and updating the software on TV to the Latest one.
Thanks
Hi Mate,
Could you please send theinstrcution to me as well. I'm having the same issue on my TV.
Thanks
I also have the same issue although my model is KDL-43W805C could you please share your fix as it is driving me mad!
thank you
Could you kindly share the fix with me as well, I have the same issue.
many thanks
Hi!
I have the same issue with my 50w755 , i cannot install the update even from USB the tv recognizes the update starting to copy and after a second its restarting..
Could you please tell me the solution too?
hi i have the same problem with updating my tv KDL 43w756c could you please help me?
Can you PM me the instructions please
Hello, send instruction. my tv sony kd 55x8505c
Never received an email to resolve this
Never reeived message
