- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have the same issue (error 2123). Please send me solution also. TV model - KDL-48WD653
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I too have this error 2123 and lost all the apps previously on tv. I have KDL 40WD653. I have tried a factory rest with no joy. I have also switched off tv and internet, waited but same error on reconnecting. Getting very frustrated at moment as nothing appears to work! Thank you in advance for your help and advice.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Quinnicus,
Could you please help me too? I have the same problem as the others above with KDL40W605B.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Very frustrating issue that is apparently known to Sony so why dont they just post a solution on their site?
I tried different routers, wifi, ethernet, usb updates (different stick as well) ...non of them worked on my 49x83. Would be nice if somebody could help please...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am facing same issue with software update on my Android TV KDL-43W950C. The update through wifi does not work and gives error 2123. I downloaded the update on USB and tried updating. The TV recognizes the update, starts copying the update file but then restarts at 47 %. The Android dancing logo comes, TV restarts once again and the update is not completed. It still has the old software version. Have tried doing factory reset, different USB drives etc, but nothing worked.
Can anyone help please? This has become really frustrating for me.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Quinnicus!
I'm having the same problem alot of people have, I've got the kdl-50W808C, when applying a software update, it stops at 14%ish, won't update, even with the usb method. Please help!
Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello I have a problem with the TV KDL-48WD653. Network error 2123. Can you help me?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Добры день! У меня проблема при обновлении Интернет содержимого на телевизоре kdl-42w653. При загрузке обновления выдает ошибку 2123. На заводские настройки сбрасовал, пробовал обновить прошивку но у меня и так последняя PKG4.600EUA. На роутере менял DNS на 8.8.8.8, не помогло. При обновлении список серверов пуст.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Unfortunately I’m experiencing the same issue as a result of an auto download
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I have the same problem. Could you please help me. Model - 49xf7005
