Hi to all, im having problems updating my w755. When i want to update android software im always stuck on 88% and having error 2123 (An error occurred during the software update, . The update server in temporarily unavailable. Please try again later Error: 2123). Ive tried several time, over cable, wifi, nothing. Always stuck on 88%. Same thing with fw, ive downloaded fw from sony site, connect usb to tv, the fw starts to copying and again on 88% tv restarts. So if anybody nows how to resolve this, please help! Thanks!
Hi Quinnicus
Same problem here, please help,,maybe your solution can be applied to my TV: XBR65X850C
Thanks
Hi
I am having the same problem on a 50W755C. Could you share the details?
Many thanks.
Hi @loquini and @gileshoughton
I have sent you both a PM with some instructions. Let me know how you get on.
Hi! Could you please send me these instructions - I'm experiencing the same problem with my KD-55X8507C. Thank you!
Fantastic - thank you!
Hello !!
Please.
My english is bad. 😃
I have the same problem with a XBR-55X855C (Android) the upgrade goes to 85%.
Thank you.
Edgar.
Take it back and say the firmware supplied by Sony killed it....
Can you confirm which country you are located it, as the model of your tv, XBR indicates you are not in the UK or Europe?
Hi @Anonymous, I have the same problem. Can you please tell me what to do?
Thank you very much !
