Sony Premium Remote: Where to buy?
Sanman1
Hi, I recently purchased a Sony BRAVIA KD43XH8196BU that came with a premium remote which I believe is model SONY RMF-TX600E. I ended up returning this TV and upgraded to the Sony BRAVIA KD49XH9505BU but surprisingly it came with a standard remote RMF-TX500E.
The RMF-TX600E is a far better remote and would like to know if it’s compatible with the Sony BRAVIA KD49XH9505BU and if so, where can I purchase it?
I believe that that there’s a premium backlit version RMF-TX611E as well but again I’m struggling to find OEM stockists.
Your advice/suggestions are most welcomed :slight_smile:
4 REPLIES 4
williamfsmith
I have seen the RMF-TX600E remote on Ebay but not the backlit version.
As all XG and XH 9505's currently share the same Firmware I suspect the premium remote would work with a 49".
Worst case, if it didn't work you could return it for a full refund on Ebay.
Sanman1
thanks for the reply. I just came across one on Amazon as well. I think I’ll give it a try but always apprehensive as to whether I’m purchasing oem or fake. Not sure why remotes are so hard to come by and why Sony doesn’t sell direct or have a publicly known reseller.
williamfsmith
If they are the metallic clad premium models I doubt they are fake. Its the cheaper plastic versions they copy.
Even on Ebay the "OEM" versions of the metallic model are circa £50.
Joe_Dohn
Specialist
Sony does have a publicly known reseller.
