lindave8182
Switching on
Should my tv run through 20 seconds of coloured shapes every time I switch it on?
Can I stop this?
2 ACCEPTED SOLUTIONS
LightFoot
Specialist
@lindave8182 wrote:
Only when I switch it on at the mains which I discovered following your reply, thank you. I am not a great believer in leaving things in standby but could do so for short periods during the day.
Hi @lindave8182  As you have discovered your TV has been designed to be left in Standby. By switching off at the mains you are probably shortening its life and as you have found it has to do a full boot of the Android operating system every time you switch it on. The annual cost of leaving it in Standby is about 50p. That's £0.50 a year!
lindave8182
Not switching off at the mains does the job thank you. It is now a case of training myself to leave it in standby, I believe it is a generational problem although I leave my Virgin Media box in standby permanently.
We can safely say you have solved my problem.
4 REPLIES 4
LightFoot
Specialist
Can I stop this?
Hi @lindave8182. Could you clarify what you mean by switch it on? Switch on at the mains or press the power button on out of Standby.
lindave8182
LightFoot
Specialist
lindave8182
