Hi All,
I have been able to get ahold of a SWF-BR100 for an older Sony Android TV I have. Unfortunately I don't have the wireless transceiver UWT-BR100 that is also needed. There isn't even one on eBay anywhere in the world Does anyone know if there is an alternative component that can be used, or is that option a non starter?
Thanks for your time.
You could try to contact the Assistance (Repair Centre) in the area, they might have an old spare part or something that they have recovered:
https://www.sony.co.uk/electronics/support/articles/00244641
Thanks, I'll give that a go.
