UWT-BR100 replacement
Konnergh
Hi All,
I have been able to get ahold of a SWF-BR100 for an older Sony Android TV I have. Unfortunately I don't have the wireless transceiver UWT-BR100 that is also needed. There isn't even one on eBay anywhere in the world :slight_smile: Does anyone know if there is an alternative component that can be used, or is that option a non starter?
Thanks for your time.
2 REPLIES 2
You could try to contact the Assistance (Repair Centre) in the area, they might have an old spare part or something that they have recovered:
https://www.sony.co.uk/electronics/support/articles/00244641
Konnergh
Thanks, I'll give that a go.
