Voice Search only displaying YouTube results 😡
Dogomatic
When I first searched google using the voice search button at the top of the remote
it displayed a whole array of types of results ! Now it only displays YouTube results.
So I could ask "show me the nearest Curry House" and
it shows videos from YouTube relating to curry houses !
Like I said at the start it would show my near by curry houses had I asked that. Then I could follow on aswell i.e "what's there telephone number" but now. Nothing 😡😔
please help !!!
11 REPLIES 11
Dogomatic
And I own a new KD55XD8599BU thanks
Anonymous
Not applicable
Hi there
Ive just been testing this too on my KD-55XD8577 - and i also cannot do google searches.  According to Googles documentation it should work.  Will see if i can find out more info.
https://support.google.com/googletv/answer/2853568?hl=en
profile.country.GR.title
MiCal1967
Contributor
Voice search
I have:
  • Google Play Movies and TV
  • Live Channels
  • TV events
  • Apps
  • Youtube
Depends on what you ask
But no Opera search
profile.country.UA.title
svansvan
Contributor
This technical documentation for developers (not necessarily delve):
https://developer.android.com/training/tv/discovery/in-app-search.html?hl=ru
If you have installed an application that implements this interface (SearchResultProvider)
the applications will appear in the search results (of course, if what you're looking for will be found in them)
everything depends on the application developers, they did it or not :slight_smile:
for more information:
http://corochann.com/android-tv-application-hands-on-tutorial-12-287.html
KD-55x9305c + SPS4 1208b
Anonymous
Not applicable
Hi @MiCal1967
Can you try doing a couple of voice searches?  I want to know if there is a difference on 2015 TVs compared to 2016.
Using the OPs example firstly: "show me the nearest curry houses"
undefined
"google Jennifer Lopez"
undefined
"search Jennifer Lopez"
undefined
"square root of 64"
undefined
"weather in Timbuktu"
undefined
MiCal1967
Contributor
Exactly the same results
Anonymous
Not applicable
Thanks :thumbsup:
TVScreenBoy
I have the same problem.
Plus, I'm trying to figure out how to voice command volume up and down. When I say "TV volume up", it shows a bunch of YouTube videos on volume.
I can change the channel, but can't change volume! How stupid can Android TV be?
mobilyuk
Same herr, only YouTube results from voice searches
