will the sony af8 ever get as bright as the lg c8 with a software update
profile.country.SE.title
zzcool
i spent most of my savings on this tv and was extremely disappointed to find out the lg c8 gets brighter, i know they both use the same panels is it a software issue or a hardware issue?
this video shows how big the difference really is, will it ever get fixed so they look the same because this is a horrible realization to me.
2 REPLIES 2
EdwinaU
Hi there,
Welcome to the forum.
We don't have any specific news about future updates but the latest updates will appear here and you can check to see if there are any changes. Meanwhile, here are some tips to adjust picture settings and brightness.
Best wishes,
Ed
zzcool
but have you acknowledged the issue, why does the c8 get brighter than the af8, why is that? you have never explained that.
i have everything set to max sometimes it appears bright to my eyes sometimes dim, the difference between lumancy medium and high is so small that i can't even see any changes, my xperia xz1 clearly shows a brighter white picture than my af8.
