Wired Ethernet stopped working
Blondie79
My TV used to work on Ethernet. That has now stopped working. For some reason it won’t connect over Wi-Fi either. So  I’ve now changed Ethernet cable which works on other devices and I get the lights on the switch. But still getting an Ethernet is not connected message. I’ve deleted all Wi-Fi profiles. Under wired LAN it says connected. Any suggestions?
3 REPLIES 3
Joe_Dohn
Specialist
Can you share the model number of your TV and the software version it's currently on?
Blondie79
Software is 8.0.0 and tv is model
is 43XE8005
Joe_Dohn
Specialist
8.0.0 is the Android version, the TV has a "package" version, it begins with PKG on the Help page. You can find the latest version for this model here.
