XD85 All Apps Are Crashing.
matchappreciated
Hello, hopefully someone can help me!
My TV was working completely fine last night, but as of this morning it constantly brings up "Unfortunately X has Stopped" when I haven't even tried opening anything.
Some examples are Bluetooth Share, com.sony.dtv.osplanevisibilitymanager, ModelvariationProvider and TV Storage.
When I try to access the settings that just closes immediately and gives me the same popup.
I've looked through google but I'm struggling to find an answer, we've only had this TV about two weeks as well.
Thanks for any help!
profile.country.AT.title
Kuschelmonschter
Hero
Do a complete restart via long power button press or power cycling the TV...
This might happen sometimes. General stability of Sony Android TV is poor....
2 REPLIES 2
Kuschelmonschter
Hero
matchappreciated
Thank you, I can't believe the problem was so easily fixed!
The long power button hold worked for me!
Thanks Again!
