- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xh 8196 locks motionflow
Is there any way to adjust motionflow on non native sony apps? I can only adjust it on native media player, netflix and watching tv. In any other apps it says that is unavailable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It is happening on custom apps like MX player, VLC player etc. Native media player, Netflix and youtube are ok. Smoothness and MOtionflow are locked. Smoothness is locked to 3 on vivid picture settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What's the problem with using the native app if it works? I'm not sure why this is happening but it could be a compatibility issue. Have you tried a factory reset just in case?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes, i also did a factory reset. Didnt fix the problem, i also did all the updates. I dont use native apps because if i plug an HDD it takes long time to index it...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi mtampou, on the third-party apps that you download it's not guaranteed that all the settings will work.
- « Previous
- 1
- 2
- Next »
