I couldn't remote lock my C3
skwid
hi!
My phone was stolen last monday and i believe that the thief flashed it or do a hard reset (just a hunch, maybe) because i've been monitoring it on myexperia since monday (evening after it was stolen) and my phone doesnt appear. is there a way i could prevent them from using my phone? thanks in advance!!
profile.country.RO.title
_alexdon_
If the device has been reset, there is nothing you can do beside contacting a police station.
With internet still enabled and the device not reset, there was a slight chance for you to find it.
I am really sorry.
alexdon
5 REPLIES 5
_alexdon_
I am really sorry.
alexdon
Christofer
Champion
Hi @skwid,
I'm sorry to hear that. Slightly_frowning_Face
You could also try tracking the phone using Android Device Manager but if that doesn't work either it sounds like your phone has been factory reset, or similar, like you suspect. In that case you will unfortunately not be able to remote lock it or do so it can't be used.
skwid
Thank you sir for your response!
skwid
Thank you sir for your kind response, i'll try that rightaway..
Christofer
Champion
Let us know if it works out for you. Slightly_smiling_Face
