I got problem while updating Android 4.2.2 16.0.B.2.13 firmware using PC Companion
hemanths94
I got problem while updating Android 4.2.2 16.0.B.2.13 firmware using PC Companion  and then my phone is not working.Now it just show the sony text  on screen and it doesn't turn off or turn on Slightly_frowning_Face :'( .please someone help what to do now??
Tags (2)
21 REPLIES 21
jalu
Press the volume up button n power key for ten secs. To shut it down.
Shivdutt
Download Perfect Flash tool by WMSHUA. Download an ftf file for the latest version.
Open the flash tool.
Now press the power and volume down button together and hold them till the red light blinks again. Then leave the power button while still holding the volume down button. Perfect flash will detect your device.
Now go to flash option and select the downloaded ftf file. Then click on flash.
The phone will start updating and it might be slow. Once it reaches 97%, From 97% to 98% will take bout 20 mins but don't unplug the device.
Once the flash finishes, remove the usb and turn on your device. The first boot will take time but now you have your phone back.
I recommend using this firmware:
http://www.gizmobolt.com/community/thread/download-xperia-c-16-0-b-2-16-firmware-ftf/
