is there any way to clear ram using task manager
ROZWIĄZANE
Manish2013
Początkujący
Hi
Can you pkease let me know how to clear ram and how to open task manager in Xperia c
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
Anand_95
Początkujący
It is an app which you can download from play store
Wyświetl rozwiązanie w oryginalnym poście
6 ODPOW. 6
Uliwooly
You can use a taskiller or task manager BUT this will create other issues, from connectivity issues, apps crashing, draining your battery faster, etc.
Android will free up RAM as need it
Manish2013
Początkujący
Can you please let me know how to open task manager???
Anand_95
Początkujący
hassan216
Początkujący
dont clear ram it will drain battery faster and you will loose smooth in the phone ..forget about the ram and do what you want you have 1gb ram
Uliwooly
You should not use those apps, but if you do and another app or apps are acting up, your battery drain faster, you know what the issue is
09031
Początkujący
How to clear RAM IN sony c having low internal memory and not possible to download New apps as phone factory apps are existed.,and no chance to download New apps even the install position prefers to sd card.
Give solution.
