McAfee problems help!
Gpn
I have purchase a Xeperia C two weeks ago, but till now McAfee Security not activate,
When put the mobile no for registration.. all time its back to home screen.
 pls help.
profile.country.RO.title
_alexdon_
Are you sure you want to use antivirus?Your problem is that mcafee does not activate?
alexdon
7 REPLIES 7
_alexdon_
alexdon
Gpn
Yes i want to install this anti virus
Gpn
Till now i can't activatate MaAfee antivirus................ how can i activate.............
_alexdon_
Settings-apps-all,look for it and enable.If not,you need to download from google play.
alexdon
SRV
Settings>Apps>McAfee>clear data, clear cache
See if it works now. Also make sure you have good internet connectivity.
Gpn
clear chache.... start McAfee....verify phone no... put my ph no removed by alexdon - no private info on the forum.. press conninue.. verifying number ... tife left... then again back to home screen error show " we could not veryfy your phone number please enter your phone number and try again" ..... in this processes i am using 3g connection....
_alexdon_
Try to use a wifi connection.Also,contact the app developers.
alexdon
