MESSAGING STOPPED WORKING
Nasimul
When I open the "Messaging" option, it automaticly become off showing the message " Message unfortunately stopped"
My device's android version is 4.2.2
It has some other problems, such as when I keep it in my pocket locked, some apps opens automatically
What can I do ??
profile.country.RO.title
_alexdon_
For the message app,try settings-apps-all-messages,force stop and clear data.
For apps opening themselves,do you have a screen protector?
alexdon
5 REPLIES 5
_alexdon_
alexdon
Nasimul
I just use pattern lock, no other protector
_alexdon_
No that kind of protector,I am talking about physical screen protector (film).
alexdon
Tags (1)
flip79
I'm getting this to. I've cleared data checked with network made sure settings are correct still stops working. It's just with media messages I've also checked storage
tompook
No reasonable answer then. Poor effort Sony.
