Hassan2017
No signal
No singl on my phon ned helps
5 REPLIES 5
ChloeS
Contributor
Hi @Hassan2017
Welcome to the community!
Sorry to hear about this, have you lost all signal so you're unable to send or receive SMS messages, make or receive phone calls etc?
Let me know Slightly_smiling_Face
recii
Pls help me.my xperia c4 dont have signal after i upgrade to marsmallow.
Uliwooly
@recii
Did you flashed the phone or did you used XC?
gregoryopera
Contributor
@uliwooly wrote:
@recii
In other words @Hassan2017, did you download your new firmware (software) "over-the-air" (OTA - directly onto your smartphone), did you use Xperia Companion to perform the upgrade or was this a custom ROM that you installed?
Also, do you have another mobile device you can test your SIM in? If you're getting coverage with another device, it's probably your smartphone at fault; if you are not getting coverage with another device, you SIM is at fault.
If you could answer these questions, we can continue to help you.
Adham1995
Same problem here i lose signal after flashing marshmallow rom from SAMSONY.NET please help if there any way to fix this problem.
I want ask  if i repaire my c4 E5333 using Xperia companion can fix it?
Sorry for my bad english Grinning_Face_with_smiling_Eyes
