Podziel się wrażeniami!
Unfortunately, the process android.process.acore has stopped.
This error show in Display..
Hi @buchi91,
I'm sorry to hear this.
I would recommend that you clear data for your contacts app. You can do this if you go to: Settings > Apps > Contacts > Storage > Clear data. Then restart your device and see if you are still experiencing the same behavior.
If you are I recommend that you reset your app preferences, you can do this if you go to: Settings > Apps > Tap the ... > Reset app preferences. Once again restart your device and check if you are still receiving the same error message.
Let me know how it goes.
After 3 days using factory reset . I fade up i did everything and process talk about this issue . Unless an application might cause this issue like truecaller . Whattsapp . Viber . Facebook . Facebook messenger . Line . Which mean i will use the xperia z1 .just for talk
await for any feed back or comments
How can I process Android acore has been stopped
