usb connection problem
Ali98
My device Does not connected to pc
Uliwooly
4 REPLIES 4
Uliwooly
@Ali98
install xc on your pc
Xperia Companion
JORGELUIS
I can't connect my phone to the computer
NO PUEDO CONECTAR USB A LA COMPUTADORA AL CELULAR
Uliwooly
@JORGELUIS
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Have you tested with a different USB cable?  different USB connector ? different computer?
haze2
i have some problem, even i change 3 usb cable, charging is ok, but no connection on experia companion and PC windows 10.
