Xperia C developer mode
raghavk
Hi All,
How can I enable developer mode in Sony Xperia C??
Can anybody help me??
Thnaks in advance.
Regards
Uliwooly
Settings > about phone > tap 3 or 4 times fast on build number
10 REPLIES 10
Uliwooly
saicharan
What the use of developer mode
raghavk
Thanks...
True_Rathour
How to disable developer mode and what is debug app
profile.country.RO.title
_alexdon_
To disable developer mode,go to settings-apps-all,find the settings app and clear data.
alexdon
True_Rathour
1. how does developer mode affects phone?
2. internal storage of Xperia c is said to be 4 gb but odd showing only .98gb. why so?
_alexdon_
Developer mode is supposed to be used by developers to improve,test or check some of the phone's functions.If you use them,you need to be careful.Well,from 4 GB you have the OS,default apps and updates.
alexdon
SonaliMangal
Now that i have once I have used this usb debigging mode ,
I cannot connect my phone to my laptop even after turning the debugging mode off.
I dunno why the **bleep** this is happeining
Slightly_frowning_Face  Crying_Face
chintupatel4464
thanks bro
