Xperia Hang while updating anroid
DP1991
My xperia whle updating got interrupted due to poor internet connection,
Now its not starting nor rebooting,
Only showing sony screen continuosuly ,nothing is happening plz help me out
Uliwooly
Install PCC > restart your PC > run PCC > repair/update your phone, make sure to charge your phone for 30-40 minutes
7 REPLIES 7
Uliwooly
You will need to repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
http://talk.sonymobile.com/thread/36355
DP1991
How to do it through PCC plz explain
Tags (1)
Uliwooly
DP1991
It is still not happening its showing an error while doing so, telling to check the internet connction,
Internet connection is working fine
Uliwooly
go to speedtest.com and check how fast/slow your connection is.
also make sure to disable your firewall and antivirus, it wouldn't hurt to try a different USB port
DP1991
Thank you so much people present  here.
I have resolved the problem using option of PCC - Repair option.
thank you so much for your valuable feeed back,
Keep it up..!!
SONY rocks..!!
Uliwooly
Anytime
