How to Update Firmware Sony HDR-CX115E
profile.country.el_GR.title
GeorgeKam
How to Update Firmware Sony HDR-CX115E ??
3 REPLIES 3
profile.country.en_GB.title
Mick2011
Hi George
Any firmware that becomes available will be downloadable from the Sony Support page for your model:
http://support.sony-europe.com/dime/camcorders/hd/msc/msc.aspx?site=odw_en_GB&m=HDR-CX115E
There doesn't appear to be an update at present, however if you check back occasionally this is the place to find any future releases. You simply download and it will update automatically when you connect the camera to the PC.
Mick
GeorgeKam
I have observed the sony does not make upload firmware for home user cameras ....
Why ?.... i have one sony dcr-sr50e old camcorder and i have the same problem with firmware.
Mick2011
George, could you possibly elaborate a little on the reason you need a firmware update for these cameras? I'm not sure I properly understand the problem.
Mick
