Importing from HDR -CX190E to an Imac
profile.country.en_GB.title
Renjiabarai
I have a pc and a mac the camera imports fine to the pc but my mac which is why video editing machine wont recognize the format ive tried a couple of converters and they wont work either
Any help would be great
11 REPLIES 11
Renjiabarai
Thanks for all the help guys it still isnt working so now it looks like ive got to buy another new operating system
looking at the mac website it says the altest is mountain lion would that one be ok to use?
Mick2011
Anything from 10.6 onwards should work. I've seen no reports of issues with any OS newer than that so I have to assume Mountain Lion should be fine.
One thing you could try before upgrading (I can't recall if this is possible with iMovie '09 or not) is removing the SD card from the camera and inserting it into the iMac's SD slot. With some OS incarnations iMovie will automatically recognise this as an attached camera and bring up the import screen. You may have to go [FIle] > [Import from camera...] but it shouldn't be necessary.
Mick
