jontrac
DSC HX9V
Hi, I've recently bought a DSC HX9V camera as an upgrade from my previous DSC N2.  In the guide it indicates that the camera will accept both SD and Memory Stick/Pro Duo cards, yet I've been unable to insert the latter.  Is an adaptor necessary or have I just misread the guide.  Any advice would be most appreciated.
Many thanks
1 REPLY 1
profile.country.en_GB.title
Mick2011
Hi jontrac, welcome to the Sony Forums :slight_smile:
You don't need an adaptor for MemorySticks. Are you sure you have it facing the right way? With the camera facing you, the card's notched corner shoudl be on the left.
Mick
