- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
how to take raw file shots with DSC-HX7V ?
Was indicated on the guide the camera can take raw file formats.
Can´t seem to find any setting for it.
Anyone knows ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Where did you see that RAW capture was a feature of the DSC-HX7V?
The specifications list the supported file formats as : -
Still images: JPEG (DCF Ver. 2.0, Exif Ver. 2.3, MPF Baseline) compliant, DPOF compatible 3D still images: MPO (MPF Extended (Disparity Image)) compliant
Movies (AVCHD format):
AVCHD
Video: MPEG-4 AVC/H.264
Audio: Dolby Digital 2ch, equipped with Dolby Digital Stereo Creator
• Manufactured under license from Dolby Laboratories.
Movies (MP4 format):
Audio: MPEG-4 AAC-LC 2ch
So it looks like RAW format is not supported - just JPEG. You are not confusing RAW shooting with the "Clear RAW NR"? This is something different - it is an image processing feature that reduces grain when using high ISO settings.
http://www.sony.co.uk/product/dsc-h-series/dsc-hx7v#pageType=TechnicalSpecs
