Hx90v picture sizes
Smit18
Hx90v picture sizes
My new hx90v is giving me 6mb picture sizes but the headline file size advertised is 18mb. I have the Fine setting turned on so don't understand why the difference.
Nobody-in-particular
Contributor
Are you possibly confusing the megapixels of an image quality with size of the megabytes file created on the data card?
An 18 megapixel file of around 6mb sounds ok the image size should measure roughly 5186 x 3456.
3 REPLIES 3
Contributor
Smit18
Many thanks, I now understand.
Contributor
You are very welcome.
If you are interested you could upload and share your images in the Photo Gallery
