E4G starting random apps
Cvele
Sometimes, my phone opens random app on exiting app that I've opened. Today, mu desktop viber asked to scan QR code, I turned on wifi on phone, viber automatically started QR scanner, and when it scanned code my phone went to Easy home mode. Few days ago I was using crhome to check some website I'm working on, and when I closed chrome there was Album opened, I closed Album and some other app was opened (can't remeber which one). None of these apps was in recent apps. Current build number is 25.0.A.2.31.
Uliwooly
@Cvele
That's a third party app, it will be hard to find which app its causing this, you can test it in >>> safe mode this mode will disable third party apps, if you don't encounter the same issue, you will have to uninstall app by app until you find the culprit
5 REPLIES 5
Uliwooly
@Cvele
Cvele
Thank you for your reply, I thought maybe someone had same problem, I'll try to narrow it down. It didn't happen last two days. I've restarted phone for the first time since I got it, except when android was updated, and that I was on the first day.
Uliwooly
@Cvele
Test it in safe mode and report back.
Cvele
Didn't test it in safe mode, it stoped launching random apps. I will report if something similar happens in the future.
Uliwooly
@Cvele
Great to hear that, keep us updated.
