Help with newest update
braydon678
I recently updated my Sony xperia e with the newest update (e.g.. With widget side bar in lock screen). I accidentally changed it back to the original lock screen and I'm wondering how I can change it back?
Thanks
Alexander1
Champion
Try to clear data for the lock screen. Go to settings > apps>  all > lock screen > clear data.
Restart phone and try again.
3 REPLIES 3
Alexander1
Champion
braydon678
Thanks for replying. I did what u said and it didn't seem to work but that's probably because I messed up the update
Vengence
Contributor
Which lockscreen are you talking about? Could you upload a picture
