How to turn off TalkBack and accessibility
Littlesid1
I have set my xperia e phone to text to speech and can not turn it back off anyone got suggestions please
Topic edited by Rickard
30 REPLIES 30
Kellyann
Cheers, my boy been driving me crazy with his phone with this problem...sorted now 🙂
kingarthuros
hi, have foud on youtube how to just go on Youtube.com and search for how to disable talk back on android.for some reason here it doesnt let me post the link but you will find it,
@Littlesid1 wrote:
tried power and volume buttons .. nothing ..... have tried computer companian  repair my phone .... no luck with that ... when holding power button push volume up just keeps saying volume 100%....
deehal
it is easy to scroll , if you use 2 fingers , i've just fixed my phone in 2 minuetes from a utube video , if the screen wont let you scorll , you must use 2 fingers to scroll to un lock your screen , then tap settings , then useing 2 fingers scroll to accsesabilty and tap talk back , and tapp twice to turn off
MANOJKUMARDARLA
Many a solutions like flash tool, Volume Up+Power doesn't work always,,,i suggest every one do this  "to scroll through the menus with talkback on by double tap and scroll with two fingers. Took a bit to get it right, but its finally done!!!!!
credit MJKumar
FMMUbashir
The best ever solution I saw is: https://www.youtube.com/watch?v=cKXE3sZj5Y0
Five minutes solution.
fgggh_
By using two fingers on the touchsceen, you will be able to scroll up or down
aryansingh
biut when we reset the phone......we lost our all contact number feeded in phone......so how can we save our contact?????????
please please help me
nissanka1
Hello i need your help
my phone is on talk back mode and when i go to settings>accessability is shows the sync account. my device is sony xperia v LT25i. how can i get rid of talk back and where can i find that option in xperia v.. please help
Hayles
My phone won't let me turn anything on in this area anyone any have anything to help me?
It says an app is stopping my settings but I haven't added a new app!
Hayles
I have worked it out it was my blue light filter because I was allowing it to draw over other apps and that stopped it madnes!!!
