Lock Screen Problem
MusicalPanda47
Lock Screen Problem
Hi, I've had my Sony Xperia E1 for about two months. But I changed my lock screen to passcode. Now I can't change it back to swipe. What can I do?
Jake-SonyXperia
Champion
Unfortunately yes, it will remove any data from the phones memory, however it will not touch an SD card or SIM card.
10 REPLIES 10
Phy
Legend
Legend
Phy
Legend
Legend
If your phone is running lollipop
1. Settings
2. Security
3. Clear credentials
Jake-SonyXperia
Champion
Hi MusicalPanda47,
Welcome to the community,
If the instructions above do not help, then I can only advise that you perform a software repair on the device to remove the lock code.
Use the instructions below.
1. Before you start you have to download the PC Companion software from PC Companion
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
Sachin4u
You can just format it and then update using the built in update center from your phone
MusicalPanda47
Hi. Will formatting a phone wipe all data out? I've got quite a lot of photos & apps.
Jake-SonyXperia
Champion
MusicalPanda47
Hi Jake-SonyXperiaSupport
Will formatting a phone affect apps on an SD card? Also, will formatting a phone erase all bookmarks on the internet and remove any Gmail accoun? Will formatting erase all the apps that were on the phone before it was sold, like, Album, Photos, Chrome, Messages, Browser and others?
Thanks for your help.
Jake-SonyXperia
Champion
Performing a Factory reset will remove all content from the device, apart from the SD card, it be like the first day you purchased the product.
konsulten
After updating to new Android my Xperia E1 is even slower and some problems occured, like the screen locks and I have to hard boot my phone, I cant swipe at all on the screen.
