Screen problem during a call Xperia E3
Teffi
I have a problem. My Xperia E3 turn of the screen during the calls even if i am not talking with it in my ear and do not let me cancel the call until the answer machine close the call. How can i solve it?? Please help. And thanks
Jake-SonyXperia
Champion
Hi Teffi,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Can you advise if you are using some screen protector or case on that device?
These may very well be affecting the proximity sensor of the device, if so I suggest trying to remove them and then testing it.
Please let me know.
14 REPLIES 14
Teffi
Btw i plug the charger and does not worrk neither
Ashroft98
Enthusiast
How long have you been facing this?
And
Can you try this?
Go to Settings > About Phone > Diagnostic > Proximity Sensor test.
See if your proximity sensor works.
Jake-SonyXperia
Champion
Hi Teffi,
Please let me know.
Teffi
Does not work
Ashroft98
Enthusiast
I see.
Then there might be a faulty proximity sensor.You may need to bring your device to a local Sony Xperia Center.But first you need to contact them.
Contact Local Sony Xperia
http://support.sonymobile.com/global-en/contactUs/
Teffi
Thanks my dear friend. The screen Protector was the problem. Then it means i can not use screen protector?
Phy
Legend
Legend
You can use a screen protector, as long as it doesn't cover the proximity sensor.
Teffi
Thank you but how I know which is properly without spend my money in vain?
Uliwooly
