Sony experia e4 cant remove app.
Catanmax
Hi and thanks in advance for any help. I can't remove an app from my son's phone. He downloaded a Minecraft screen lock which he has tried to uninstall. It's not being removed and we can't click uninstall. Anyone any ideas? Ty. Cat.
Christofer
Champion
I tried downloading the app myself. Turns out you need to go to Settings > Security > Device administrators and then deactivate the app here first. After doing this you should be able to uninstall the app like you normally would do.
5 REPLIES 5
Christofer
Champion
Hi @Catanmax,
Could you try restarting the phone into safe mode and then check again if you can uninstall this app?
Catanmax
Tried that, still can't uninstall. Slightly_frowning_Face
Christofer
Champion
Catanmax
Thank you Christopher! That has worked! Cheers, cat.
Christofer
Champion
Glad to hear that, you're welcome! Slightly_smiling_Face
