Sony Xperia E Not taking pictures
BoroParmo
When I goto take a photo on my xperia E it is saying the memory is full on the phone however when I check the storage menu it says I have 6.5gb free, when I check that menu also only 'apps' appears. 'Photos' appear but then goes straight off not allowing me to click it, please let me know if you have a solution or have faced this problem, thanks in advance!
profile.country.RO.title
_alexdon_
12 REPLIES 12
_alexdon_
Where do you store them? Perhaps internal memory is filled up and microSD memory is free.
alexdon
BoroParmo
I'm not sure, I've never used it to take pictures until yesterday when I opened the camera to take some and a message popped up saying 'memory full'
_alexdon_
Go to camera-settings-data storage,select your SD card.
alexdon
BoroParmo
Can't find settings anywhere after opening the camera, is it under another menu?
_alexdon_
Open the camera,tap on the 3 dots,tap on the screwdriver and wrench and there you should find it.
alexdon
BoroParmo
Hi Alex, when I click the camera there isn't 3 dots, all I have is Geotagging, timer, EV and 'Scenes' I'm I in the right area?
_alexdon_
Probably you are on superior auto,but still you should have it. Can you post a screenshot?
alexdon
BoroParmo
BoroParmo
Hope that helps, I know its not very clear but its the best I could do
