Xperia E1 Overcharged?
ZiM
Hey, Today i've been doing some tests with a lead and acid battery at 5,2V and 4,5 A/H .  I plugged my Xperia E1 in the battery using the usb charger connected to the battery, and the phone, well, the charging led became green, 5 secons later red and the phone shut down. now, the phone is "dead" and the charging led is allways red...   has it any solution? is the phone dead forever?
Uliwooly
@ZiM
You should contact your local Xperia Care and get it inspected
http://support.sonymobile.com/global-en/contactUs/
15 REPLIES 15
Uliwooly
@ZiM
ZiM
@uliwooly wrote:
@ZiM
  okay, but what do you think? do you think is it dead?
Uliwooly
It might be
ZiM
@uliwooly wrote:
It might be
Slightly_frowning_Face
Uliwooly
@ZiM
Don't despair, just get it inspected, it might not be dead.
ZiM
thanks dude, but i'm really nervous, i've burned my phone lol Slightly_frowning_Face  I've an insurance , but i don't think it covers that 😕
Uliwooly
Thommo
Was a bit silly exceeding the voltage and amps - Far to many amps and slightly to many volts so from seeing similar things I'd say you have blown a micro fuse
ZiM
@uliwooly wrote:
@ZiM'
Got your message, this is how to boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
yeah, but i can't open the phone so i can't select "reboot in safe mode".
