Have just charged my PRS 650 for the first time and now it won't turn on. What to do?
Hi, if you have fully charged the unit and will not power from the button, try a reset and then plug back into usb cable, you should see the connection symbol and charge indicator, now remove the Reader and try again, if it continues not to function i would advise dealer or service dependant on its warrenty status
Hello. I have the same problem of you.
I attach the screen message.
Now do you resolv it?
Paolo
