Hi. Can anyone help? I am trying to find some Sony Head Cleaning Tapes KCS-5CL for a U-Matic Video Cassette Player
profile.country.en_GB.title
johnIWM
I am trying to find some Sony Head Cleaning Tapes KCS-5CL for a U-Matic Video Cassette Player. This is an obsolete format extensively used in the 1970's by the army. The cassettes are still available but so far I have been unable to locate any of the head cleaning tapes.
pcamichel
Have a look at this site, they seem to have them in stock.  I hope this helps.
http://www.svsmedia.orangehome.co.uk/wv2.htm
2 REPLIES 2
pcamichel
Flowmo
If you can't find a head cleaning tape, these are very easy to clean without one. As the head unit is big and easy to get to you should have no problem.
