- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony MCH-V73D
Hi all has anybody had a problem with Bluetooth on the above system? I have reset the stereo and once this has completed it will connect to my devices but if you switch it off and then back on it will not pair and connect until I do another reset. Can anybody help ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does this happen no matter what's the device connected to it? Or does it happen with a specific device?
You can find information here as well: http://bit.ly/3tcyiFu & http://bit.ly/3K0BeLh.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi it happens on all devices the only way i can connect is to perform a reset every time it will then connect but soon as i turn it off it just flashes and will not pair to anything if i do a search from Alexa or iPhone nothing is found
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi its all devices I have taken in for repair as I think it’s a hard ware problem and it’s under 6 months old it will be repaired under warranty thank you for your messages and support
thanks
paul
