- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have tried setting up this function as per instructions given in the manuals and cannot get any sound from my tv to the home cinema unit. The manual says on the TV settings to switch sound from "tv speakers" to "audio system" which I have done and the sound should come through on the "TV" setting of the home cinema unit which it doesn't.
I've tried 3 different HDMI cables incase any were faulty but still nothing.
Any help on this matter would be greatly appreciated.
Chris.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Firstly, you need to connect a HDMI Cable from the TV's HDMI 1 (ARC) port to the N7200W (HDMI-OUT-ARC). You cannot use other HDMI ports on the TV - only the one specified as ARC. Also ensure that your HDMI cables have ARC functionality. HDMI version 1.4.
Ensure that Bravia Sync is switched on, on the TV and N7200W (should be by default). And then set TV Speakers to Audio System.
Ensure that the N7200W is also switched ON.
If you can confirm that and it still doesnt work - please reply back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The Bravia Sync was disabled.
After enabling it, it is working perfectly.
Many thanks for your help, it has been much appreciated.
Chris.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your most welcome - Glad your now up and running
