hi im looking to find a replacement lamp for bravia lcd projection 50 inch kdf-50e2000 any help out there plz CANT DO WITHOUT FOR XMAS HOUSE FULL
profile.country.en_IE.title
DOREEN135
profile.country.en_GB.title
Catmambo
Contributor
Have you contacted the support line? They should be able to advise. Details at the top of the page.
Thanks
1 REPLY 1
Catmambo
Contributor
Thanks
