HT-G700 loss of sound
Gillett27
When I'm watching TV on Sky or normal TV I now and then lose the sound for a second or so and then it comes back on.
When this happens you see on the sound bar the audio format the sound is playing.  It's a relatively small issue but annoying
Tags (1)
3 REPLIES 3
Joe_Dohn
Specialist
How is it connected to the TV and what model TV are you using with it?
Gillett27
Hi its commented via a HDMI cable and both the eArc on the sound bar and TV
is switched on.
The Hdmi is a 2.1 cable that's supports 8k. The TV is an LG OLED55BX6LB
Thanks.
Joe_Dohn
Specialist
Have you tried connecting it to a different audio device (other TV, laptop, PC, etc.)?
